[e39 530dA] Prośba o interpretację błędów z INPA.
Witam, bardzo proszę o pomoc w interpretacji błędów które udało mi się wyciągnąć za pomocą INPA.
W sekcji Engine:
RESULT: 2 errors in error memory !
__________________________________________________________
7680 CAN - bus
Error frequency : 1 Logistic counter: 13
Engine speed 874.13 1/min
Supply voltage 13.77 V
Einspritzmenge 2.05 mm^3
driving speed 47.08 km/h
Fehler aufgetreten bei 332350.00 km
Error not present Instrument-cluster reception fault (INSTR3)
Errorcode: 1E 00 0D 01 70 04 23 77 04 2E 81 D3 00 00 00 00 00 00 00 00 00 00 00 00 00 =============================================================
ECU: DDE40KW0
JobStatus: OKAY
Variant: DDE40KW0
7728 Charge-air pressure control or charge-air pressure actuator
Error frequency : 14
Logistic counter: 39
Error occured 1. times at:
Engine speed 2372.63 1/min
Coolant temperature 89.37 Grad C
Einspritzmenge 38.91 mm^3
Boost pressure 1408.00 mbar
Fehler aufgetreten bei 329330.00 km
Error occured 2. times at:
Engine speed 1523.48 1/min
Coolant temperature 94.15 Grad C
Einspritzmenge 34.82 mm^3
Boost pressure 1152.00 mbar
Fehler aufgetreten bei 332400.00 km
Error occured 3. times at:
Engine speed 2772.23 1/min
Coolant temperature 105.75 Grad C
Einspritzmenge 38.40 mm^3
Boost pressure 1440.00 mbar
Fehler aufgetreten bei 332940.00 km
Error present Sporadic error pos. deviation / Boost pressure to low
Errorcode: 1E 30 27 0E FC 10 5F BF 4C 58 80 A5 10 3D C6 44 48 81 D8 10 6F D7 4B 5A 82
____________________________________________________________
Transmission
ECU: GS20
JobStatus: OKAY
Variant: GS20
RESULT: 1 errors in error memory !
131 CAN-Time-Out Cluster
Error frequency : 1
Logistic counter: 0
km value 332350.00 km
Engine speed 864.00 rpm
Output Speed 1024.00 rpm
Battery Voltage 13.80 Volt
General error Sporadic error
No i tu jak dobrze rozumiem to błąd w wyniku mojego odłączenia akumulatora
ECU: ZUHEIZ
JobStatus: OKAY
Variant: ZUHEIZ
7 Under voltage cut off
Error frequency : 255
Water pump ON 48.00 0-n
Cooling temperature 25.00
degrees Celsius
Implausible value, Invalid working area
E R R O R M E M O R Y R E P O R T -------------------------------------
Date: 07/28/14 16:18:29
ECU: PDCACT
JobStatus: OKAY
Variant: PDCACT
RESULT: 4 errors in error memory !
20 ultrasonic sensor front left
Error frequency : 11
short circuit suppliercable/datacable to ground
Open circuit Sporadic error
21 ultrasonic sensor front right
22 ultrasonic sensor front middle left
23 ultrasonic sensor front middle right
ECU:       IRIS
JobStatus: OKAY
Variant:   IRIS
0     Unknown error location
Error frequency : 1
  Error not present
ECU:       DSC57
JobStatus: OKAY
Variant:   DSC57
97    steering angle adjustment necessary
Error frequency : 1
  Vehicle speed      2.63  km/h
  ASC not passiv
  ABS-control passiv
  stop light switch off
  ASC-control passiv
  ACB passive
  HBA passive
  ECD passive
  HDC passive
ECU:       ZKE3_GM1
JobStatus: OKAY
Variant:   ZKE3_GM1
131   DWA-Alarm : door contact FT
Error frequency : 2
  Static error
147   power up from the GM III
Error frequency : 4
  Static error
