Emblemat X5 na tylnej klapie
Czy ktos dysponuje wymiarami albo jakims szablonem gdzie dokladnie na tylnej klapie przykleic emblemat , chcialbym zeby wygladalo to profesjonalnie jak z fabryki
http://res.bmwcats.com/tis/1091876.png
Affix tape upper edge (1) parallel to the bottom edge of the tailgate (2) at a distance "A".
Make a mark on the upper edge of the adhesive tape at a distance "B" from the lateral edge (3).
Dimensions for E53:
A = 22 mm; B = 53 mm
Dimensions for E70:
A = 20 mm; B = 57 mm
Note:
Size "C" is given for information only, as it is defined by the base film.
C = 8,7 mm
Dzieki!!! O to mi chodzilo
