Z cd na ccc profesional dodatkowe kable
Jakeb
Widzę ze pare osób jest zainteresowanych tematem , więc zamieszcze odpowiedz
If you look at the back of the CCC unit you will see at the left FAN with its connector (3 pin connector from left to right pins 1,2,3) and at the right side there are also two connectors on top of the third one.
You need to take 3 wires and connect the following:
Pin 1 (from left to right, when looking from the back of the ccc unit) of the FAN connector to the pin 5 of the small 12 pin connector (left one out of the two).
Pin 2 (from left to right, when looking from the back of the ccc unit) of the FAN connector to the pin 11 of the small 12 pin connector (left one out of the two).
Pin 3 (from left to right, when looking from the back of the ccc unit) of the FAN connector to the pin 1 of the small 12 pin connector (left one out of the two).
