mikolaj2909
Treść opublikowana przez mikolaj2909
  1. Patrz co znalazłem mam ten sam problem i chcę go rozwiązać,jest po angielsku można przetłumaczć w translator . This is the TSB for the solenoid replacement which the dealer followed, which sadly still didn't fix the problem. The computer and DME was even reset and reprogrammed with the latest versions. --------------------- SI B 11 05 05 Engine December 2006 Technical Service This Service Information bulletin supersedes S.I. B11 05 05 dated November 2006. SUBJECT N52 Engine Runs Poorly with Camshaft Sensor and VANOS Faults MODEL E90 (3 Series), E60 (5 Series) with N52 engine produced from 3/2005 through 6/2005 E90, E91 and E92 (3 Series) with N52KP and N54 engines from 7/2006 production E85 and E84 (Z4) with N52 from 1/2006 production E83 (X3) with N52 from 9/2006 production SITUATION Vehicles equipped with the N52, N52KP and N54 engines may be difficult to start, run rough and have the "Service Engine Soon" light illuminated. Any of the following camshaft sensor or VANOS faults, as well as various misfire faults, may be stored in DME fault memory. • 2A9A Cam sensor, inlet signal – signal invalid for synchronization • 2A98 Crankshaft-inlet camshaft, correlation- Value outside reference range • 2A82 VANOS intake- stiff, jammed mechanically • 2A9B Cam sensor, exhaust signal – signal invalid for synchronization • 2A99 Crankshaft- exhaust camshaft, correlation- Value outside reference range • 2A87 VANOS exhaust- stiff, jammed mechanically CAUSE VANOS solenoid valve is jammed or sticking. CORRECTION On a customer complaint basis only, perform the diagnosis and repair procedure as described below. PROCEDURE E90 (3 Series), E60 (5 Series) with N52 only: Remove the VANOS solenoid, intake or exhaust depending on the fault codes stored, and using shop air, gently blow out any visible particles and reinstall. It is no longer necessary to replace the VANOS solenoid on the N52 Engine. Reprogram the vehicle using CIP17.01 (Target data Status E89x-05-06-510), or higher for the E90 and Target data Status E060-05-06-500, or higher for the E60. The modified MSV70 DME data contains additional VANOS solenoid activation logic to flush out any foreign particles. E90, E91 and E92 (3 Series) with N52KP and N54 engine, E83, E85, E86 with N52 engine only: Swap the faulted VANOS solenoid with the opposing solenoid to verify if the fault follows to opposing location. If the fault follows replace the VANOS solenoid. PARTS INFORMATION Part Number Description Quantity 11 36 7 516 293 VANOS Solenoid 1 WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty. Defect Code Refer to KSD Labor Operation: Refer to KSD Labor Allowance: Refer to KSD
  2. Znalazłem na forum zagranicznym,zmienił na olej amsoil i ucichło ,kiedy nadszedł czas na nastepną zmiane oleju ,i zrobiono to w ASO po jakimś czasie znów tykało, zmienił spowrotem na amsoil i ucichło i mnie jest cicho mam przebieg równe 70000km,w każdym razie nie ma to znaczenia jeśli chodzi otrwałość silnika nie uszkadza się nic. tu masz procedurę odpowietrzania samoregulatowów tak robią w aso Intermittent hydrauliczny Regulacja zaworu (HVA) "Tkanina" czy "grzechotanie" Hałasy MODEL Wszystkie E83, E85, E86, E60, E61, E70, E90, E91, E92 i E93 z N52 lub ​​N52K silników SYTUACJI okazjonalnego zaznaczając lub grzechotanie hałas HVA elementów może wystąpić podczas rozruchu zimnego silnika lub częstego krótkim dystansowi. Przyczyna W takich sytuacjach nie można elementy HVA dostarczono jeszcze wystarczającą ilość powietrza bez oleju. Warunek ten nie spowoduje uszkodzenia silnika i zazwyczaj się z środków prawnych dłuższej jazdy odległość lub czas pracy przy pełnej temperatury roboczej. KOREKTA W przypadku reklamacji klienta należy wykonać poniższą procedurę odpowietrzania HVA. PROCEDURE WAŻNE UWAGI: Strumień Czas ten może trwać dwóch minut (w rzadkich przypadkach) maksymalnie 30 minut. Procedura ta ma być wykonywana na równej powierzchni, przy pojeździe nieruchomym, w odpowiednio wentylowanym pomieszczeniu. Postępowanie wstępne: poziom oleju w silniku są prawidłowe? ani pod wypełnione ani przepełnione Silnik pracuje w temperaturze roboczej 1. Doprowadzić silnik do prędkości pracy (bez obciążenia) z 2000 roku? 3000 rpm i utrzymać ten stan przez trzy minuty (krwawienie procedurę). 2. Niech silnik bezczynny przez 15? 30 sekund i ponownie ocenić, czy hałas jest nadal obecny, czy nie. 3. Silnik cicho? Procedura jest zakończona. 4. Hałas silnika jest nadal obecny? Powtarzaj procedurę? Kroki # 1 i # 2 do maksymalnie 5 razy. 5. Tylko wtedy, gdy hałas pozostaje po wykonaniu procedury krwawienie 5 razy? przejść wykonując procedurę po raz ostatni, również przy prędkości pracy silnika 2000? 3000 rpm, ale na całkowity czas trwania 15 minut. GWARANCJA objęte warunkami Nowego BMW Pojazdu gwarancją. SI B 11 09 07 Silnik lipca 2007 Obsługa techniczna Strona 1 z 3 http://www.bmwtis.net / tiscode/cgi-bin/omcg...tm_store/9397 .. . 26.12.2007 Uwaga: Poniższe wyjaśnienia uzmysłowi właściwego wykorzystania czasu pracy. Kod Defect 11 12 94 39 00 00 57 Działanie Pracy 087 Wykonaj krwawienie do trzech razy głównej pracy Pracy Uprawnień 5 FRU Pracy Operation 00 57 088 Wykonaj krwawienie 5 kompletnych razy Main Work Allowance 7 FRU Labor Labor Operation 00 57 089 Wykonanie krwawienie 5 kompletnych razy plus dodatkowe 15 minut krwawić uruchamiać Main Work Allowance 11 FRU Labor Labor Operation 00 57 717 Wykonanie krwawienie do trzech razy + Associated Work Allowance Labor 3 FRU Labor Operation 00 57 718 Wykonanie krwawienie 5 kompletnych razy + Associated Work Allowance 5 FRU Labor Labor operacyjne 00 57 719 Wykonanie krwawienia 5 kompletnych razy plus dodatkowe 15 minut krwawić uruchamiane + Associated Work Allowance Pracy 9 FRU Główne prace: Użyj tej pracy, gdy numer operacji wykonywane tylko naprawa jest wyszczególniony naprawa gwarancyjna. OR Strona 2 z 3 http://www.bmwtis.net/tiscode/cgi-bin/omcg...tm_store/9397 .. . 26.12.2007 + Associated pracy: Użyj tego numeru operacji roboczej, gdy inne naprawy lub usługi . wykonywane wraz z zabytkowym naprawy gwarancyjnej . Pod żadnym pozorem nie obydwa numery operacyjne pracy
