Patrz co znalazłem mam ten sam problem i chcę go rozwiązać,jest po angielsku można przetłumaczć w translator . This is the TSB for the solenoid replacement which the dealer followed, which sadly still didn't fix the problem. The computer and DME was even reset and reprogrammed with the latest versions. --------------------- SI B 11 05 05 Engine December 2006 Technical Service This Service Information bulletin supersedes S.I. B11 05 05 dated November 2006. SUBJECT N52 Engine Runs Poorly with Camshaft Sensor and VANOS Faults MODEL E90 (3 Series), E60 (5 Series) with N52 engine produced from 3/2005 through 6/2005 E90, E91 and E92 (3 Series) with N52KP and N54 engines from 7/2006 production E85 and E84 (Z4) with N52 from 1/2006 production E83 (X3) with N52 from 9/2006 production SITUATION Vehicles equipped with the N52, N52KP and N54 engines may be difficult to start, run rough and have the "Service Engine Soon" light illuminated. Any of the following camshaft sensor or VANOS faults, as well as various misfire faults, may be stored in DME fault memory. • 2A9A Cam sensor, inlet signal – signal invalid for synchronization • 2A98 Crankshaft-inlet camshaft, correlation- Value outside reference range • 2A82 VANOS intake- stiff, jammed mechanically • 2A9B Cam sensor, exhaust signal – signal invalid for synchronization • 2A99 Crankshaft- exhaust camshaft, correlation- Value outside reference range • 2A87 VANOS exhaust- stiff, jammed mechanically CAUSE VANOS solenoid valve is jammed or sticking. CORRECTION On a customer complaint basis only, perform the diagnosis and repair procedure as described below. PROCEDURE E90 (3 Series), E60 (5 Series) with N52 only: Remove the VANOS solenoid, intake or exhaust depending on the fault codes stored, and using shop air, gently blow out any visible particles and reinstall. It is no longer necessary to replace the VANOS solenoid on the N52 Engine. Reprogram the vehicle using CIP17.01 (Target data Status E89x-05-06-510), or higher for the E90 and Target data Status E060-05-06-500, or higher for the E60. The modified MSV70 DME data contains additional VANOS solenoid activation logic to flush out any foreign particles. E90, E91 and E92 (3 Series) with N52KP and N54 engine, E83, E85, E86 with N52 engine only: Swap the faulted VANOS solenoid with the opposing solenoid to verify if the fault follows to opposing location. If the fault follows replace the VANOS solenoid. PARTS INFORMATION Part Number Description Quantity 11 36 7 516 293 VANOS Solenoid 1 WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty. Defect Code Refer to KSD Labor Operation: Refer to KSD Labor Allowance: Refer to KSD
