VIN podałem. Olej kupiłem :) Też gdzieś dogrzebałem się do informacji z TIS :) I wszystko stało się jasne :) Były 2 skrzynie: A4S 310R i A4S 270R Pierwsza z nich (A4S 310R) to skrzynia zalewana olejem Texaco Texamatic 7045E i jest to olej Lifetime. Wtedy plakietka jest zielona. I TIS podaje że tego oleju nie trzeba wymieniać. Druga (A4S 270R) to skrzynia z czarną plakietką i jest tam zalewny olej DEXRON III. Tutaj BMW zaleca wymianę co jakiś czas :) A i jeszcze jedna rzecz. Te oleje można mieszac. Texaco jest zgodny DEXRON III. wklejam info po angielsku: 8.0 Automatic transmission fluid for GM transmission A4S 310R (THM-R1), A4S 270R (THM-R1w) To distinguish between the automatic transmissions A4S 310R and A4S 270R: - Automatic transmission with oil lubrication filling for change interval. Identifying feature - black type plate on transmission housing. Regular oil change is specified for this transmission, see BMW Inspection Sheet. - Automatic transmission with lifetime lubrication. Identifying feature - green type plate on the transmission housing. No oil change is required for the entire service life of these transmissions. If repairs have to be made to the transmission or transmission oil cooler, use only the approved automatic transmission fluids. Automatic transmission fluid for transmissions with black type plate: All automatic transmission fluids, please refer to Enclosure 3.0, and all automatic transmission fluids with specification Dexron III. Note: The specification "Dexron III" is on the oil container or can be obtained from the manufacturer/supplier. Automatic transmission fluid for transmissions with green type plate: Trade name BMW part number Container size Automatic transmission fluid 83 22 0 026 922 25-litre canister ETL 7045E Note: Change lifetime oil from Dexron III to ETL 7045E, 09/01. Lifetime oils Dexron III and ETL 7045E may be mixed together.
