Maks1981
    320d e46
Osiągnięcia Maks1981
Debiutant
Debiutant (2/14)
  1. Witam ponownie , dzis po raz kolejny mimo deszczowej pogody pojechalem na kanal by sprawdzic i porobic fotki i mysle ze wszystko jest ok ale sami ocencie : http://img72.imageshack.us/img72/2858/imag0406e.th.jpg http://img839.imageshack.us/img839/3669/imag0405t.th.jpg http://img830.imageshack.us/img830/2950/imag0404l.th.jpg http://img580.imageshack.us/img580/9320/imag0403q.th.jpg http://img580.imageshack.us/img580/2351/imag0401.th.jpg http://img835.imageshack.us/img835/9130/imag0402.th.jpg http://img185.imageshack.us/img185/7452/imag0400.th.jpg http://img836.imageshack.us/img836/4853/imag0392b.th.jpg http://img825.imageshack.us/img825/4957/imag0393.th.jpg http://img248.imageshack.us/img248/1899/imag0394w.th.jpg http://img148.imageshack.us/img148/6716/imag0395h.th.jpg http://img205.imageshack.us/img205/3773/imag0396z.th.jpg http://img840.imageshack.us/img840/3820/imag0398f.th.jpg http://img248.imageshack.us/img248/7356/imag0399.th.jpg http://img6.imageshack.us/img6/4367/imag0391ha.th.jpg http://img522.imageshack.us/img522/7595/imag0390.th.jpg http://img178.imageshack.us/img178/1483/imag0389.th.jpg http://img834.imageshack.us/img834/6957/imag0387.th.jpg http://img812.imageshack.us/img812/9496/imag0388.th.jpg http://img137.imageshack.us/img137/57/imag0386.th.jpg http://img651.imageshack.us/img651/1270/imag0385t.th.jpg sam probowalem krecic walem i delikatny stuk slychac gdzies w okolocy chyba podpory ktorej zdjecie tez zalaczylem. jesli chodzi o luzy na wale to tak owych niema ,mam tu na mysli laczniki.
  2. Kolego czyli masz na mysli tuleje (poduszki) z tego rysunku ? http://www.realoem.com/bmw/showparts.do?model=AL71&mospid=47634&btnr=33_0839&hg=33&fg=30 bo jesli chodzi o lewe mocowanie z tylu to tu zalaczam fotke , mi sie wydaje ze jest ok... http://img693.imageshack.us/img693/4420/imag0363m.jpg http://img693.imageshack.us/img693/4420/imag0363m.jpg
  3. czy lacznik elastyczny to element 2 z rysunku ponizej: http://www.realoem.com/bmw/showparts.do?model=AL71&mospid=47634&btnr=26_0194&hg=26&fg=10 jesli tak to jest on po stronie silnika a u mnie definitywnie slychac to przy tylniej osi. a co myslicie o podporze walu ?? moze to ona?
  4. polosie sprawdzone zero luzow.
  5. wszystkie 7 tulejek sprawdzone i wygladaja ok . jesli natomiast chodzi o mocowanie do reszty nadwozia to nie widac zadnych naderwanych czesci jak na fotkach z linku fornala. zero jakiego kolwiek luzu przy probie szarpania wszystko stabilne a przy jezdzie ciagle to czuc i slychac. jakies pomysly ??
  6. dzis zostaly wymienione poduszki skrzyni i silnika (oryginalne takie jak na pierwszy montaz) . problem nie ustapil. jutro jade na kanal zobaczyc to mocowanie wozka. z tego co widzialem na fotkach to bardzo latwy jest do tego dostep by to spradzic?? dla jasnosci uderzenie definitywnie slychac z tylu i samochod nie wibruje nie przenosza sie zadne drgania tylko jest takie gluche uderzenie.
  7. Jak wyglada naprawa tej usterki ? wystarczy kanal ?? http://realoem.com/bmw/showparts.do?model=AL71&mospid=47634&btnr=33_0839&hg=33&fg=30&lang=pl rozumie ze to gdzies tutaj :)??
  8. raczej bardziej to czuc na biegach 3,4,5. Mam wersje przed liftem 1999 rok 136 HP. po za tym uderzaniem nic nie slychac niepokojacego.
  9. Witam. Jestem nowy na forum i stalem sie szczesliwym posiadaczem e46 320d ale niestety przy dodaniu gazu slysze dziwne uderzenie w tylnim zawieszeniu dokladnie to samo slychac gdy zalozmy jade przy wcisnietym pedale do deski i nagle go zwalniam. odczucie jest takie jak bym mial przyczepke na haku i hak mial by luz. Prosze was o pomoc bo nigdzie nie moge znalezc przyczyny i sposobu rozwiazania mojego problemu.
