marcin2010
Treść opublikowana przez marcin2010
  1. WITAM :) JUZ MOJA BMW JEZDZI :) WKONCU JA ZROBILEM CO BYLO PRZYCZYNA ZE NIE BYLO PRADU TO JUZ PISZE :) SPRAWDZILISMY KABEL OD TYLU DO PRZODU I PRAD W NIM BYL ACZ KOLWIEK NIKT NIE SPRAWDZIL NA KONCU W KOMORZE SILNIKA TEJ WSUWKI LUTOWANEJ NIBY DO ROZRUSZNIKA CO IDZIE Z OCZKIEM :) W SRODKU POKRUSZYL SIE KABEL CZYLI TE DRUCIKI I MUSIALEM NA NOWO ROZIZOLOWYWAC I NA NOWO LUTOWANIE I ZACISKANIE :) ODRAZU PO PODLACZENIU TEGO KABLA PODLACZYLEM DO AKU I NA PRUBÓWCE ZOBACZYLEM SWIATLO :> ODRAZU MI SIE BUZKA USMIECHNELA :) JUZ MOJE BMW JEZDZI I WKONCU USTERKA ZOSTALA USUNIETA ;) WIELKIE DZIEKI WSZYSTKIM ZA POMOC ;) POZDRAWIAM
  2. WITAM CIE KOLEGO SPRAWA JEST TAKA ZE ZALOZYLEM ROZRUSZNIK I WIEM ZE JEST ON SPRAWNY ALE NIESTETY Z AKUMULATORA IDZIE GRUBY KABEL W KTORYM JEST CALY CZAS PRAD I SPRAWDZALEM CALY PRZEWOD OD AKU DO KONCA BUDY CZYLI DO NOG PASAZERA I PRAD JEST, POTEM SPRAWDZALEM NEONÓWKA NA 12V PRAD POD MASKA DOKLADNIE PRZY ROZRUSZNIKU I TAM JUZ NIESTETY PRAD SIE KONCZY I DO ROZRUSZNIKA NIE DOCHODZI ON ;/ NIE WIEM CZY PO DRODZE SA JAKIES BEZPIECZNIKI CZY COS MOGLO SIE SPALIC PO DRODZE JAKIS PRZEKAZNIK CZY CO KOLWIEK, CHCIALEM KUPIC DRUGI GRUBY KABEL TAKI GRUBY ZALOZYC MU PO DRODZE BEZPIECZNIK I BEZPOSREDNIO PODLACZYC GO Z AKUMULATORA DO ROZRUSZNIKA I WTEDY BEDE WIEDZIAL ZE NA 100% BEDE MIAL PRAD CZY MOZNA BY TAK ZASTAPIC TEN KABEL POPRZEDNI CZY SA GDZIES NA NIM PO DRODZE BEZPIECZNIKI LUB JAKIES ZABEZPIECZENIA ????
  3. WITAM KOLEGE WYCIAGNOLEM ROZRUSZNIK PO CZYM GO ROZEBRALEM NA STOLE I NIESTETY POSYPAL MI SIE I POCZULEM TYLKO NIE ZACIEKAWY ZAPACH SPALENIZNY CZYLI OD STRONY SZCZOTEK MI SIE SPALIL :) SZUKAM JUZ NASTEPNEGO CO PRAWDA JEST TROCHE PROBLEM BO GDZIE NIE ZADZWONIE TO MAJA DO MANUALA A DO AUTOMATA JEST INNY ALE JUZ MI WSZYSTKO HASA TAKIE JAK SZYBY SZYBERDACH KLIMKA :D I CENTRALNY ;P AZ KAMIEN Z SERCA SPADL ;) WIELKIE DZIEKI ZA PODPOWIEDZ
  4. NO WLASNIE ZE GAZU ZATANKOWALEM PELNA BUTLE I UJECHALEM MOZE NA NIM JAKIES 10KM BENZYNY TEZ JEST POL BAKU I NIC JUTRO BIORE SIE ZA ROZRUSZNIK BO TEZ MI WLASNIE KOLEGA TO PODPOWIEDZIAL :) TAKZE DAM ZNAC CO TO BYLA ZA PRZYCZYNA :)
  5. WITAM SERDECZNIE WSZYSTKICH KLUBOWICZÓW MAM TAKI PROBLEM Z MOJA SIÓDEMKA OGOLNIE MAM BMW 3,5 LITRA A AUTOMACIE I KWESTIA JEST TAKA ZE JECHALEM SOBIE NA BIEGU D I WSZYSTKO BYLO DOBRZE DO MOMENTU AZ NIE PRZYCISNOLEM NOGA GAZU W PODLOGE I STRZELIL MI GAS ( LPG ) BMW MI STRZELILO I PO CZASIE ZGASLO WIEC ZAKULALEM SIE NA POBOCZE CHCIALEM ODPALIC JA A ONA WOGOLE JAK BY MIALA SLABY AKUMULATOR WOGOLE TO NIE WIEM KTO WLOZYL DO TAKIEGO AUTA AKUMULATOR 55 AH ZADZWONILEM PO POMOC PRZYJECHAL KOLEGA Z DRUGIM AKUMULATOREM WIEKSZYM JUZ BO 75 Ah I PODLACZYLISMY GO I LEDWO LEDWO KRECIL POSTANOWILISMY JA ZACIAGNAC NA BIEGU N CZYLI NEUTRALNYM DO MNIE DO DOMU WLOZYLISMY WIEKSZY AKUMULATOR I WTEDY JUZ WOGOLE NIE CHCIALA NAWET ZAKRECIC ROZRUSZNIKIEM, POSTANOWILEM ZE ZOSTAWIE JA I NA DRUGI DZIEN SOBIE W NIEJ POGRZEBIE BO BYLA JUZ NOC CHCIALEM ZAMKNAC SZYBERDACH A ON WOGOLE TEZ NIE DZIALA NIE SZLO GO ZAMKNAC NIE WIEM CO SIE MOGLO W NIEJ STAC :( KAZDY MI MOWI ZE MUSZE ODLACZYC AKUMULATOR I KOMPUTER MUSI SIE ZRESETOWAC JA W TAKIE BAJKI NIE WIERZE :( BMW STOI SLONECZKO SWIECI A JA NIE MAM CZYM JEZDZIC. CZY KTOS MIAL MOZE TAKI PRZYPADEK KIEDYS :(
