WA123
Treść opublikowana przez WA123
  1. PROSZĘ O ROZKODOWANIE VIN WBACE31030EU30104 Z GÓRY WIELKIE DZIĘKI
  2. WA123
    PROBLEM Z NAWIEWEM
    MYŚLĘ ŻE TO NIE JEST TAK JAK CZYTAŁEŚ, JAK MA BYĆ ZIMNE TO ZIMNE A JAK CIEPŁE TO CIEPŁE. A SŁYSZAŁEŚ MOŻE COŚ O TYM PROBLEMIE Z PRZŁĄCZANIEM NAWIEWÓW?
  3. WA123
    PROBLEM Z NAWIEWEM
    WITAM WSZYSTKICH MAM PROBLEM Z NAWIEWAMI, KTÓRY POLEGA NA TYM ŻE NIE PRZEŁĄCZJĄ SIĘ (SZYBA,ŚRODEK,NOGI) WSZYSTKO ZACZEŁO SIĘ OD AWARII PANELA KLIMATRONIK,KTÓRY JUŻ NAPRAWIŁEM ALE DOŚĆ DŁUGO JEŹDZIŁEM Z USZKODZONYM I MYŚLAŁEM ŻE TO JEGO WINA. NIESTETY PO NAPRAWIE PROBLEM NAWIEWÓW POZOSTAŁ. ZAKŁADAŁEM INNY PANEL OD KOLEGI I JEST TAK SAMO. POPROSTU NAWIEWY SĄ CZŁY CZAS OTWARTE NA ŚRODEK I NOGI A JAK WŁĄCZE KLIME TO ZAMYKAJĄ SIĘ WSZYSTKIE DOPIERO PO WYŁĄCZENIU ZAPŁONU NA DŁUŻSZY CZAS OK.GODZ. I PONOWNYM WŁĄCZENIU KLIMY TO SIĘ OTWIERAJĄ ALE TEŻ TYLKO NA ŚRODEK I NOGI W DODATKU CZĘSTO JEST TAK ŻE NA ŚRODEK LECI ZIMNE POWIETRZE Z KLIMY A NA NOGI LECI CIEPŁE. SPRAWDZAŁEM SILNICZKI STERUJĄCE KLAPKAMI I SĄ DOBRE , KLIMA BYŁA DOBIJANA NA WIOSNĘ WIĘC TEZ POWINNO BYĆ OK, PŁYN W CHŁODNICY TEŻ JEST OK. REGULACJA SIŁY NADMUCHU RÓWNIEŻ DZIAŁA W TRYBIE MANUALNYM I AUTO WIĘC JEŻ POWINIEN BYC OK. CZY JEST JEZSZE JAKIŚ STEROWNIK OD TYCH KLAPEK?? POMÓŻCIE :cry:
