ogrefifas
    BMB 525D xDrive F10, 2014
Osiągnięcia ogrefifas
Debiutant
Debiutant (2/14)
  1. ogrefifas
    New steering wheel
    Hey all. I want to change my default steering wheel on BMW 5 series F10 2014 to M-sport version. I need wheel with vibro and buttons for adaptive cruise control and also i want gearshift paddles. For now i don't have wheel heating button, but probably i want to install it, is it easy to do or not? In this case i need to buy wheel with heating, isn't it? Could you advice some shops where can i buy new or used for reasonable price? Thank you!
  2. Hi. Bought BMW 525dx, 2014, 150k kilometers. Found out under the hood that level of coolant is MIN, not between min and max as should. There no weird noises while driving, no warnings from bmw about low level, no smells, no errors, oil level in engine ideal, no smudges, everything is dry. I am planning to change all oils and liquids, but still i am interesting why it on min level and is it normal or not for this car. And how can i resolve it? I have checked on cold car this morning. Thank you!
  3. Hi everyone, recently bought BMW 5 series F10 525D xDrive, 2014, 150000 kilometers. I think that i need to change coolant and brake pads besides oil in engine and transmission. 1) Could you recommend which coolant should i select for this car? 1) Could you recommend which brake pads are better for me? 1) Could you recommend which brake fluid should i select for this car? 1) Could you recommend which brake discs should i select for this car? Links on allegro or etc. will be great! Thank you very much!
  4. i found out model of transmission: ZF GA8HP 8/1. It should help you. Thanks!
  5. I am zero in polish so i think it's better me to write in english instead of translating polish in google translate. Thank you very much for answer. Probably will by bmw twinpower as u advised. Just few questions 1) u said that only services that have equipment and agreement with BMW can change data in the car's computer. Maybe someone knows such in Warsaw with good price/quality level? 2) How often do I need to change my engine oil? 1 time every 10,000 kilometers?
  6. Dzień dobry kupiłem BMW 525d F10 xDrive 2014, przebieg 150000, czy ten olej będzie dobry dla mojego samochodu: https://allegro.pl/oferta/motul-8100-x-clean-efe-5w30-5l-gratis-8822474165 ? powiedz mi kto jeszcze w aucie pisze informacje o wymianie oleju, filtrów itp do komputera pokładowego?
  7. Dzień dobry kupiłem BMW 525d F10 xDrive 2014, przebieg 150000, chcę dokonać częściowej wymiany oleju w skrzyni. Powiedz mi, jaki olej należy wlewać iw jakiej ilości? Jeśli to możliwe, najlepiej link do allegro?
