What is the #1 composter on Amazon.com? Based on the product quality and real product reviews, as well as being one of the best-selling items, the FCMP Outdoor IM4000 Tumbling Composter is proudly selected as Amazon’s choice and is rated as the best composter among Amazon products of a similar function. Getting nearly 80% positive ratings out of 2,298 Amazon customer reviews for its incredible operation, this top reviewed unit is the best choice for your composting. For More Information: Best Consumer Products - Top List Of Product Reviewed on TheKingLive.com Reasons why this Tumbling Composter should be yours 1. It’s simple to use - Apart from the usual steps for a traditional composter, there are no more skilled requirements when putting your waste into the composter or learning the temperature for perfect composting. The thoughtful design, with large openings and detachable door, eases the composting process. You can easily add in your waste and remove the resulting compost. - The attached handgrips give you the most convenience in dealing with your composter, from turning it or transferring it to other places. - After throwing waste into it, close the door and turn it occasionally (every 2-3 days). The well-done compost will come after 2-3 weeks if the process is done right. - It is best to combine waste with a dry source, such as leaves, mulch, or used papers. Without a dry source, your compost is going to be mushy. 2. Tumbling, not stationary or rotating There are three main technical features that need to be considered when shopping around for your composter: stationary, rotating, or tumbling. While all of them are good, the tumbling composter is ranked the most effective one due to its simplicity and its excellent aeration. Selected For You: Top product reviews Thekinglive 3. Two-chambered design - These increase its composting capacity to up to 37 gallons. - It improves the composting activities continuously. The two independent sides enable one side to complete while keeping another side open to add more waste. 4. Good aerating system - Aeration in composting is the process of making it possible for air to become mixed within a composter to destroy scraps/clippings or waste. The more aeration, the more efficient your composting will be. - Advanced technology provides aeration holes and deep fins to help break down masses inside and blend the oxygen into the composter. 5. Durability This unit is produced to be an outdoor composter. Therefore, it’s designed to be durable under harsh weather conditions. - The frame is made up of galvanized steel that guards against corrosion under rain and winter snow. - The primary material is BPA free, and the composter is created from recycled polypropylene. This means that your product will be durable under direct sunlight. 4-step tumbling composting instructions 1. Begin your composting - Begin your composter’s assembly. It might take you 5 minutes to finish. - Add waste into your composter. You can add both the green waste (such as grass, fruits, vegetables, coffee grounds, and some kitchen leftovers, etc.) and brown waste (such as leaves, wood clippings, etc.). Do not compost your meat or dairy products because they will be harmful to your plant and you. 2. Spin your composter 5-7 times, once or twice a week, to make sure you’re composting appropriately. This also improves the aeration, providing enough oxygen to break down the clumps inside the composter. You will get your compost in good condition after 2-3 weeks. 3. After 2 weeks, you can place more food waste into the second chamber, and repeat step 1 for the best result. 4. Simply empty your chamber into a compost container when your compost is ready to use. Check Over Here: Best Reviews Guide - Top Product Reviews On TheKingLive As you can see, it is easy to do your composting with this appliance. You will not have to dig a hole or read a lot about traditional composting anymore. This FCMP Outdoor IM4000 Tumbling Composter is so durable, you can recycle your waste and have the perfect compost as an input for your gardening activities. Currently, it is trading at $77 on Amazon.com, which is not a big investment for this helpful and high-ranking composter.
