Witam doposażyłem swoją bunie w instalacje pod grzane lusterka no i teraz według instrukcji, zostało mi zakodowanie modułu SSS . Installation information All illustrations show LHD vehicles. Carry out the same procedure analogously on RHD vehicles. The installation procedure for the mirror wiring loom B and for the door wiring loom C is described only for the left-hand side of the vehicle. Please follow the same procedure for the right-hand side of the vehicle. When installing cables/wires, particular care must be taken to ensure that they are not bent, kinked or damaged. The costs incurred will not be reimbursed by BMW AG. Additionally installed cables/lines must be secured with cable ties. Bridges, double crimp or parallel connections must be made if the specified PIN chambers are already occupied. The condition of the control unit must be checked with the test program CIP (coding, individualising, programming) before installing the retrofit. If the check finds incorrect or faulty statuses in one or several control units, they must be first corrected/updated with the "Load software" function. After installation, the retrofit must be encoded using the software service station (SSS) via the path - CIP -. Required special tools 00 9 317, Trim panel wedge Za pomocą jakiego programu i jak to zrobić mógł by mi ktoś pomóc?
