grzesiekwie
    e46 318D Touring
Osiągnięcia grzesiekwie
  1. Witam Panowie, też odnotowałem ten błąd. Nadminię że EGR nie był zaślepiany. Czy mogę Was poprosić o bezcenne wskazówki co i jak należy sprawdzić ? Brakuje mi fachowca od BMW lokalnie... Dziękuje E R R O R M E M O R Y --------------------------------------- Date: 26.09.2016 17:34:31 ECU: D50M47A JobStatus: OKAY Variant: D50M47A ------------------------------------------------------------- RESULT: 3 error in error memory ! ------------------------------------------------------------- 4501 4501 (0401) control of exhaust re-circulation P0401 Exhaust Gas Recirculation Flow Insufficient Detected Error counter: 32 Logistic counter: 40 1. Umweltsatz Mileage 198290 km average engine rotational speed 1544.61 rpm coolant temperature 88.27 deg C maximum common-rail-pressure of last 10ms 535.64 bar injection volume setpoint without volume offset 11.03 mg/cyc intaken air mass per cylinder 623.86 mg/Hub charge pressure value 1368.61 hPa linearised APP1 18.90 % Tastverhältnis zür Endstufenansteuerung 99.25 % Tastverhältnis zür Endstufenansteuerung 76.41 % Atmospheric-pressure 1004.30 hPa 2. Umweltsatz Mileage 198340 km average engine rotational speed 1517.03 rpm coolant temperature 89.28 deg C maximum common-rail-pressure of last 10ms 519.89 bar injection volume setpoint without volume offset 11.03 mg/cyc intaken air mass per cylinder 617.56 mg/Hub charge pressure value 1329.22 hPa linearised APP1 24.41 % Tastverhältnis zür Endstufenansteuerung 96.89 % Tastverhältnis zür Endstufenansteuerung 75.62 % Atmospheric-pressure 1014.15 hPa Signal or value below threshold Test conditions not yet fulfilled Error not present now, but already stored Error would cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase Error code: 45 01 B2 06 04 01 20 28 4D 75 38 8A 44 1C 63 8B 18 7E 61 66 4D 7A 37 8B 42 1C 62 87 1F 7B 60 67 -------------------------------------------------------------
